Another New Guy With Problems!
Old Oct 24, 2011 | 11:01 AM
greenparam's Avatar
greenparam
Default Another New Guy With Problems!
Excellent site, glad I found it!
I have a 2001 Ram 1500 4x4 that is giving me some problems. Symptoms:
-Starts and runs very smooth, then idle will drop real low to almost stalling and then rev real high and drop to normal. Engine will do this a few times and clear up. When driving, engine will loose power and start popping thru the carb. Engine can be reved up at any time to clear up. Symptoms seem to go away when engine reaches full temp.
Already changed: plugs, cap, rotor, wires, pcv, down stream o2 sensor.
Appreciate any help I can get. I dont want to just keep throwing parts at.
Old Oct 24, 2011 | 12:56 PM
vpnavy's Avatar
vpnavy
Welcome Aboard greenparam! Stay tuned - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Ram for stuff related to your ride.
Old Oct 24, 2011 | 02:47 PM
turbotank's Avatar
turbotank
Are you getting any codes? {check engine light?} , you may have a fuel filter going bad, causing a drop in the injector pressure, it could also be a vacuum leak, but thats not as likely if it clears up. need more info
Old Oct 24, 2011 | 08:49 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Enjoy the site!!
Dusty
Old Oct 25, 2011 | 10:38 AM
greenparam's Avatar
greenparam
I did get the code for the down streamn O2 sensor and replaced it. Reset the the computer, but the truck is still acting the same as it did before the O2 replacement.
Thanks
Old Oct 26, 2011 | 04:10 AM
denlevi's Avatar
denlevi
check your egr valve while your at it.
