Check engine, brake, ABS light all on with other issues...HELP
Old Apr 8, 2012 | 11:16 AM
mike110104's Avatar
mike110104
Default Check engine, brake, ABS light all on with other issues...HELP
I just bought a 2000 dodge durango 2 wheel drive with 5.2; the check engine light, brake light, and ABS light came on. This is my first dodge... I need help! Any suggestions or thoughts? BTW it has 124k miles and the odometer and speedometer does not seem to be working either...
Old Apr 8, 2012 | 02:02 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Try replacing both the output sensor on the transmission and the speed sensor for the ABS on the rear diff.
Old Apr 8, 2012 | 04:33 PM
mike110104's Avatar
mike110104
Default Thank you Master Tech
I will do that and get back to you... Just curious, if i were to buy a code reader what should i buy for a to it yourselfer... is the $80 basic one ok for what i need it for?
BTW: HAPPY EASTER and thanks for the welcome!
Old Apr 9, 2012 | 12:32 AM
master tech
A code reader will only get the codes out of the PCM and that is all. You need a scanner to read all the modules.
Old Apr 9, 2012 | 03:01 AM
mike110104's Avatar
mike110104
Master Tech-
Thanks again... your wisdom is priceless! I replaced both those sensors and all those lights are gone, my speedo and odometer works and my cruise works. I bought the code reader before I saw your post.. it did help out though.. it told me i had a P0500 code which was the speed sensor... I plan on doing all my own work to this vehicle as needed so i thought it might help... Anyhow you were a great help!!! I'm sure I will have more questions in the future like performance upgrades etc... Thanks again!
