2008 Dodge Avenger Front Brake Torque Spec
Old Apr 10, 2012 | 09:16 PM
molokoplus13's Avatar
molokoplus13
Default 2008 Dodge Avenger Front Brake Torque Spec
I'm replacing front brake pads and rotors on a 2008 Dodge Avenger SXT 2.4L. I've had absolutely no luck finding the torque spec for the caliper guide bolts, mounting bolts,and wheel lug nuts.Can any shine some like on this?
Old Apr 10, 2012 | 11:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I torque the tires at 90 to 95 foot pounds. Here are some specs for the other information.
05 - Brakes/05 - Brakes, Base/Specifications
TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs.
ABS ICU Mounting Bolt (To Bracket) 11 — 97
ABS ICU Mounting Pins 11 — 97
ABS ICU Mounting Bracket Screws (To Frame) 23 17 203
ABS ICU Mounting Bracket Screw And Nut (To Frame) - Right-Hand-Drive 23 17 203
ABS ABM Mounting Screws (To HCU) 2 — 17
ABS Dynamics Sensor Mounting Nuts 9 6.5 80
ABS Wheel Speed Sensor Head Mounting Screw - Front 12 9 106
ABS Wheel Speed Sensor Head Mounting Screw - Rear 10 7 89
ABS Wheel Speed Sensor Routing Bracket Mounting Screw 18 13 160
Brake Flex Hose Banjo Bolt - Front Caliper 24 18 210
Brake Flex Hose Fitting- Rear Caliper 15 11 133
Brake Pedal/Booster Mounting Nuts 23 17 200
Brake Tube Nuts 17 12.5 150
Disc Brake Caliper Adapter Bracket (To Knuckle) - Front 108 80 —
Disc Brake Caliper Adapter Bracket (To Support) - Rear 71 52 —
Disc Brake Caliper Guide Pin Bolts - Front 43 32 —
Disc Brake Caliper Guide Pin Bolts - Rear 43 32 —
Disc Brake Caliper Bleeder Screw 8 6 71
Drum Brake Wheel Cylinder Mounting Screws 13 — 115
Drum Brake Wheel Cylinder Bleeder Screw 10 — 89
Fluid Reservoir Mounting Screw 5.5 4 48
Master Cylinder Mounting Nuts 25 18 221
Parking Brake Lever Mounting Nuts 28 21 250
Proportioning Valves 30 22 —
Wheel Mounting (Lug) Nuts 135 100 —
Old Apr 11, 2012 | 01:31 PM
molokoplus13
Default Thank you Master Tech.
Thank you Master Tech. I've searched the web and there is nothing on this subject,well, until now that is. The part stores don't have manuals yet and the dealerships are tight lipped. Your a life saver. Now I can this project done and move on to the next. Thanks again
