Shadow ES 3.0 Trans Problem
Old May 2, 2012 | 08:51 AM
Mr.BiggNJ's Avatar
Mr.BiggNJ
Default Shadow ES 3.0 Trans Problem
Hi,
I have a 93 Shadow ES 3.0. I’m having a transmission problem. Most of the time the car is ok. Sometimes when I go to drive it, it won’t get out of first gear. I shut it off wait a few minutes start it back up and it will drive fine. Shifts gears at all the right points no slipping or anything. I park come back out start it up, won’t get out of first gear. I changed the speed sensors and the shift solenoid. It still does the same thing. I will drive perfectly fine for a week or so and then it will stop shifting. Is the trans shot or is there anything else I can try before looking for a new trans?
Thanks
Old May 3, 2012 | 12:45 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The transmissionis going into limp in. The best way to find out whats going on with the transmission is to pull codes out of the TCM. You will find the blue connector near the fuse box door. That connector is for the transmission and ABS. The connector under the hood is only for the spec or PCM.
Old May 3, 2012 | 07:59 AM
Mr.BiggNJ's Avatar
Mr.BiggNJ
Thank you! I will try and get the codes and see whats up.
Old Sep 21, 2012 | 10:17 AM
Mr.BiggNJ's Avatar
Mr.BiggNJ
I am having difficulty finding someone who can read the codes. Do you think it would be worth for $80 to change the computer? It would cost just as much for someone to just read the computer. I have changed the speed sensors, the shift pack, the fluid (replaced with fluid from dealer), I changed a loose motor mount. It still goes into limp mode. IT can be in limp mode when I first start it. I shut it off wait and restart and then it will be ok.
Old Sep 23, 2012 | 09:44 PM
master tech
You need the dealer to check for your transmission codes. Have them write down the codes, CVI and perform a clutch test. They should know how to do all the things i have writen. And if they don't know how, let me know and give me the phone number and i'll call them.
