need help with truck not getting fire???
Hello to all. This is my first post here and I am hoping to find some resolution to an issue I have with a 1998 dodge dakota, not producing any fire. It is 2 wheel drive, 3.2 V-8.
It all started with a leak at the timing chain cover gasket. I admit when it comes to autos I can sometimes know just enough to get me in trouble. However. after researching ,although the labor involved was quite timely, it seemed pretty straight forward. I followed step by step instructions and felt I had done a pretty thorough job. Used extreme caution in all areas. Anyway got the thing back together and have no fire. I researched some more and really cannot see that anything I would have messed with would cause this type of issue. So, decided I better go a little deeper in research. My check engine light was on so I bought a scanner. The code was PO 340. Camshaft position sensor. So I replaced.- Nothing. Read that sometimes you can get this reading and it be the Crankshaft position sensor. So I replaced.- Nothing. And I cleared the code after changing both of these. I double checked all my connections. Looking for loose ground. Checked all relays and fuses.-all look good. Check battery power.Checked power from alternator. Still no fire. I have a family member who is a mechanic. He stopped by the house and he basically checked everything I did and went a little deeper. He is just as baffled as I am. He suggest changing the coil and the ignition module. But before I did that I wanted to post here to get any additional ideas. I am a little confuse that anything I did would have caused this issue. Like I said I used extreme caution -even disconnecting the negative battery cable. Is there anything inside the timing housing tha I might have hit in putting it back together that would cause my truck not to fire? Any help offered would be greatly appreciated.
Thanks
Thanks
Welcome to Dodge Forum! You might get a better response by posting here: https://dodgeforum.com/forum/2nd-gen-dakota-67/
It's the Dakota Forums.
