need some help
Old Sep 10, 2012 | 09:56 PM
mleverman9's Avatar
mleverman9
New Member
Default need some help
So I have a 2003 dodge ram 1500, with a 5.7 hemi. Like an idiot a bought the truck from someone that took the cats off of it. Well there is supposed to be 2 oxygen sensors before and after the cat. Well someone also condensed the 4 oxys into 2. The truck is running too rich. The oxygen sensor is running in a constant open loop. I really dont want to have to spend a lot of money putting cats back in the truck. Im about to change the front oxygen sensor over to an oem one to see if that does anything. I was wondering if anyone has taking the cats of there truck and was able to make it run okay, or am i going to be forced to put them back in and re wire for the 4 oxygen sensor. Any input would be appreciated!
thanks mark
Old Sep 11, 2012 | 03:53 AM
Countryboy_4_life's Avatar
Countryboy_4_life
welcome to Dodge Forum
anytime sensors are removed problems are going to be caused. as far as I'm aware, unless there is some way to trick the computer using some sort of tuner (and then there still migh be performance issues to deal with) the only way to fix it is to put back what is supposed to be there.
