minivan problems
Old Sep 19, 2012 | 07:02 PM
bkm564's Avatar
bkm564
Default minivan problems
I have a 99 Caravan. It was down for a few months with the engine torn down, bad cam. When I put it back together and tried to start it , nothing happened. Checked the starter and it is fine. I was told it was the security system, and to lock and unlock the passenger door a few times. This did nothing. I did the same on the drivers door with the same results. Can anyone help. I really need it on the road.
Old Sep 23, 2012 | 10:05 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
First always make sure the battery is fully charged. If the battery is good and the engine doesn't crank. Hook up and battery charger and leave the key on for one hour. Because if the skim module has locked you out, this unlock the module so it will at least turn over.
