tranny problems??
Old Aug 17, 2013 | 11:49 PM
98dodge2500.'s Avatar
98dodge2500.
Default tranny problems??
Recently my 98 2500 automatic dodge has been having problems with shifting. when I'm driving about 45-55 mph it shifts up and down constantly. All the fluids are fine, but after i had changed the oil, it was working perfectly. I don't know why it does that and what the problem is. and its also at 309,000 miles everything stock. Don't know if i should replace the tranny or what the problem is. Can someone help??
Old Aug 18, 2013 | 08:37 AM
Welcome to DF.
Check the throttle position sensor. If the RPM change is right about 200 RPM, that is a good indicator the sensor is going bad.
Old Aug 18, 2013 | 09:02 AM
Welcome to DF! Also check out the 2nd gen Ram section. Lots of good info on transmissions and other common problems with these trucks can be found there.
