Hey everyone first post on DF PLEASE help at ends wits
Old Jan 21, 2014 | 01:21 PM
jpjaj2's Avatar
jpjaj2
Default Hey everyone first post on DF PLEASE help at ends wits
Hey all,
I am looking for a while on here to see if I can find an answer to my issue. I couldn't pinpoint it so I figure id ask. I recently had a new jasper 5.2l installed in my 1996 ram 1500. The old motor was having issues(low compression high mileage) and I decided to replace new instead of rebuilding.
The issue im having is the lack of power and poor fuel mileage with new motor. I average 9.5-10.5 mpg. The old motor was getting 13.5-14 even with issues.
Things done when motor installed,
New crank and cam sensor
New pace setter headers
New magna flow hi flow cat
Summit racing cat back exhaust 3"in dual 2 1/4 out
Ive checked for vacuum leaks, fuel pressure, timing, etc.
I had garage put on scanner and the tps is at .6v and 3.8 wot we feel this could be the issue but im asking all if anyone thinks is could be something im not thinking of.
Thanks to all
Last edited by jpjaj2; Jan 21, 2014 at 01:24 PM. Reason: forgot some info had to add in
Old Jan 21, 2014 | 01:32 PM
jpjaj2's Avatar
jpjaj2
This is on my 4x4 not the two wheel drive. Everything on the truck is the same as before the new motor was installed.
Old Jan 21, 2014 | 02:23 PM
Post up your question in the 2nd gen Ram section
Old Jan 21, 2014 | 03:20 PM
How old are your O2 sensors?
Old Jan 21, 2014 | 05:35 PM
jpjaj2's Avatar
jpjaj2
Thanks jkeaton ill post it in the 2nd gen section.
Hey you I replaced the o2 sensors when I put the new engine and exhaust system on.
Old Jan 21, 2014 | 06:31 PM
Thanks. 2nd gen Ram technical section is for posting your technical issues.
Old Jan 22, 2014 | 04:34 AM
CorinePerez's Avatar
CorinePerez
There might be some leakage out there.
