2008 nitro shuts off when heater is running
Old Oct 20, 2018 | 06:37 PM
Laforgefam18's Avatar
Laforgefam18
Default 2008 nitro shuts off when heater is running
I have a 2008 dodge nitro. I have recently replace 2 oxygen sensors. It is still rough while it is in idle. It kind of has a bouncing feeling. Anyway, when I run my air, everything is fine. It has shut off on me occasionally. But when I run the heat, it shuts off while driving ALOT! Could it be the other 2 sensors needing replaced or a whole separate issue? Also, my wipers are stuck on the on position and will not shut off, and my signal lights will not work at all. If anyone could help me out with ideas please!!! It's so frustrating! Cause my only option at the moment is pulling the fuse when I don't need my wipers and putting it back in when I need them. Thank you!!!!!
Old Oct 20, 2018 | 07:50 PM
Welcome to DF! You want to post your question in the Nitro section. Also, getting a real factory service manual, with accurate wiring diagrams, would be a VERY good idea.
Old Oct 20, 2018 | 11:08 PM
Welcome to DF. As stated, you will get better responses by posting in the technical section specific to your vehicle.
Old Oct 21, 2018 | 09:24 PM
Nate N.'s Avatar
Nate N.
Welcome!!
Old Oct 23, 2018 | 02:45 AM
dodgeciho's Avatar
dodgeciho
New Member
Hello. Welcome to the forum
