Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
HELP! Nitrous install on 1969 dodge charger
Old May 3, 2008 | 10:05 PM
Johnnyp's Avatar
Johnnyp
Default HELP! Nitrous install on 1969 dodge charger
i just bought a NOS sniper kit for my car. will i need to upgrade my stock mechanical fuel pump to run a 100 shot?
Old May 11, 2008 | 08:18 PM
superdak05's Avatar
superdak05
Default RE: HELP! Nitrous install on 1969 dodge charger
first thing you will have to do is check the line pressure with a guage. if it falls short of the recommened pressure required to run the system then yes. if not you are good to go. i just put a zex wet system on my dodge dakota and worth every penny.
Old May 13, 2008 | 12:11 AM
12 volt's Avatar
12 volt
nos sniper owners manual
http://www.nitroussupply.com/pdf/070...a7001-snos.pdf
just for kicks
nos owners manual for wet kit
http://www.nitroussupply.com/pdf/05130%20Wet%20kit.pdf
Old May 14, 2008 | 03:34 PM
Horseapples's Avatar
Horseapples
The safest way to run nitrous on a carb system is to install an electric fuel pump dedicated to the nos system. The Holley red pump is pre set to 7 psi and will flow 97 gallons per hour so no regulator will be needed. Simply plumb into the fuel supply line, if you have 5/16 line you will need to upgrade to 3/8, and wire it to your nitrous arming switch at the relay.
http://store.summitracing.com/egnsea...115+4294785043
