Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
stratus rt
Old Oct 20, 2005 | 03:37 AM
  #21
X_Spearmint's Avatar
X_Spearmint
Default RE: stratus rt
just a thought, but since the motor is the same as the one in the newer eclipse why not go take a look at what turbos are out there for it? you'd probably need to do some modification too get it to fit into the engine bay, but atleast you know it'll be tuned for your motor.
Old Dec 4, 2005 | 01:58 AM
  #22
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
ORIGINAL: 71RoadRunner
It all depends on if it's a coupe(2-door) or a sedan(4-door). The coupe is mitsubishi powered and the sedan is all Chrysler. The mitsubishi is more likely to have an existing turbo set-up already made for it.
It depends on how much is different between the Mitsubishi DOHC 3.0L used in the 3000GT/Stealth and the Mitsubishi SOHC 3.0L used in the Eclipse, Stratus/Sebring coupes as well.
Old Dec 6, 2005 | 11:25 PM
  #23
longislandboi85's Avatar
longislandboi85
any chance that the turbo manifold off the turbo strat in mexico will fit my 2.4l motor? If so that would be a great strating point for a kit.
Old Dec 29, 2005 | 01:42 PM
  #24
X_Spearmint
Go look on the Stratus forum. I posted a link to where you can get a turbo kit that will bolt onto a Stratus R/T.
https://dodgeforum.com/m.asp?m=356362&mpage=1&key=
Old Mar 12, 2006 | 04:47 AM
  #25
joe0121's Avatar
joe0121
The engine in the 2002 3.0L R/T is the same engine that went into that years Eclipse, in fact it is nearly the same car. In most cases you can buy used Turbo's in good shape make the headers and down pipe yuourself or find a turbo kit for the 2002 Eclips. However RIPP makes a stage three supercharge get that run 9 PSI of boost (Just about the safe limit withing going to fordged pistons and connecting rods ETC) for 3,600 I think.
If you have the money go with the super charger IMHO.
Old May 12, 2006 | 06:38 AM
  #26
soffa r/t's Avatar
soffa r/t
i once saw a super charger on ebay for 01 stratus r/t, but only if you want to spend $3000 or more!
