Other Vintage Dodges Discuss your J,F,M, anc C bodies here!
engine application question for ya old school gurus
Old Jul 26, 2007 | 07:34 PM
HellaciousHemi's Avatar
HellaciousHemi
Default engine application question for ya old school gurus
My buddy has a 1961 Fury and its got a big block but im not sure which is in the engine bay. I am guessin its a 413 RB series but from what i know it could be a 400 or a 383 B seriestoo. What could i look for fast to determine whats under the hood without lookin at the VIN or should i just look at the VIN for starters anyways.
Old Jul 31, 2007 | 04:56 PM
HellaciousHemi
Default RE: engine application question for ya old school gurus
Nobody knows what digit on the VIN I could look at for determining what engine it is?
Old Jul 31, 2007 | 07:02 PM
JokerzVeng's Avatar
JokerzVeng
what kinda of intake manifold does it have the old flat cross-ram???
Old Jul 31, 2007 | 10:54 PM
gtxpooch's Avatar
gtxpooch
Not sure about that year but I think the 5th digit is the engine is the vin.
Old Jul 31, 2007 | 11:11 PM
HellaciousHemi
It has a 2bbl intake, nothing special.
Old Aug 1, 2007 | 08:05 AM
TeeWJay426's Avatar
TeeWJay426
I'm not sure if the VIN gave the engine size back in 1961 or not..... best source for 1955-1961 Mopar info is here: www.forwardlook.net . Most likely, if it's a 2 barrel, it's probably a 361. If you can get to the casting number on the side of the block, that would tell you for sure. If it's missing the raised pad to the left of the distributor on the front of the engine, it's either a 361 or 383. Take another look and see if you can get a little more info.
Old Jan 24, 2008 | 12:05 AM
moe7404's Avatar
moe7404
moe in wichita ks
i think that the vin doesnt show engine size untill 65, or 66. if its a daily driver dont use a cam with more than 264 degrees duration advertised. this is not the .05 lift number. or it will use to much fuel.
