Other Vintage Dodges Discuss your J,F,M, anc C bodies here!
dodge mirada
Old Dec 26, 2020 | 09:53 PM
mopar426h's Avatar
mopar426h
Default dodge mirada
i was wondering what rear ends will bolt into a mirada. i know they came with 7.25 and 8.25 rear ends from the factory. im wanting a rear that can be built for 750hp with out spending an arm and a leg. thanks
Old Dec 27, 2020 | 09:48 AM
Moparite's Avatar
Moparite
Stick or auto? You can have dana 60 modded to fit but not exactly cheap. They where used on the hemi cars. Next would be the 9 1/4 they where installed in a lot of vehicles from 1970 to around 2000. You have to match up the spring perch and overall length. Last would be the 8 3/4.
Old Dec 27, 2020 | 11:24 AM
mopar426h's Avatar
mopar426h
i plan on using a 727 torqeflite. would the 8.75 or 9.25 be a "bolt in". who bulids 8.25 rearends and could a 7.25 or 8.25 be built to handle that much hp
Old Dec 27, 2020 | 12:33 PM
I think the 7.25 is definitely a "no"..... you would grenade that in pretty short order. The 8.25 is a *maybe*.... I could likely be built to withstand the power, but, it would not be inexpensive. I don't think you will find something that will just 'bolt right in', aside from special ordering something. (again, not cheap....) I suspect at the very least, you will need to shuffle mounts around on whatever you get.
Old Dec 27, 2020 | 01:50 PM
mopar426h's Avatar
mopar426h
im seeing that the j bodies are very similar to the f and m bodies which were based on a bodies. would a 9 inch with a body mounts work
Old Dec 27, 2020 | 09:46 PM
mopar426h's Avatar
mopar426h
anybody
Old Dec 27, 2020 | 09:56 PM
Don't know. Get measurements of the axle that is under it at the moment, and then compare those to measurements from any other axle you are considering using.
Old Dec 28, 2020 | 06:11 PM
Moparite's Avatar
Moparite
This may help...
https://www.bigblockmopar.nl/tech/mo...le-dimensions/
