PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
sentry key
Old Mar 4, 2006 | 10:37 PM
silvermagnum's Avatar
silvermagnum
Default sentry key
Does anyone know what this is? Why doesn't anyone have any information about it? My car won't start now that I changed the battery.
Old Mar 16, 2006 | 12:18 AM
stantheman's Avatar
stantheman
Default RE: sentry key
Havent changed the battery in one yet but i think your gonna need to tow it to a dealer. There are going to be some things that will need to be reset. Dont have a clue why dcx did it that way but they did.
Old May 24, 2006 | 10:44 PM
Gone Fishin's Avatar
Gone Fishin
The Sentry key has a chip in it, that is encoded to the specific vehicle that is using it. If the vehicle is started not using the Sentry key, the PCM shuts down the fuel pump within 30 seconds--It comes from the factory as part of the security package, but can be added after the fact.
Old Jun 3, 2006 | 08:49 PM
014x459's Avatar
014x459
ORIGINAL: Gone Fishin
Actually it stalls the vehicle out after more like 2 seconds of running. But you should not have a problem with your sentry key just because you cnhanged your battery, unless something else is going on with the vehicle.
What is the problem you are having? No Start No Crank? Crank but no start? Runs for a few seconds and then stall out? What kind of a vehicle?
