PCM & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
My '01 1500 engine light is on!! need help!
Old Feb 8, 2007 | 11:21 PM
DaRooster751's Avatar
DaRooster751
Default My '01 1500 engine light is on!! need help!
Hi, my name is Chad. i own a '01 Ram 1500 4x4. I just bought it around the 1st of last December. I was driving home today and noticed the engine light on and noticed when I idle or slow at a stop it seems to run erratically, kinda like a misfire. Keep in mind I live in central Ohio and the temperaturein the last week has been at or below freezing. So when I got homeI checked for the code and as expected, up came a misfire code (P0306, misfire in cylinder #6). It has a 5.9L V8 in it. Could it be a dirty or clogged injector? What should I do? I run 87 octane in it and have half a tank left. Should I wait till empty and dump some injector cleaner in it, or can I dothis now?? Should I run a tank of 93 octane plus injector cleaner to remedy the problem? I'm just trying to find an easy fix before taking it to a service desk. Any other suggestions if any of the above solutions doesn't work? I hope its only the injector, please be the injector. Thanks to all who reply. Oh, this is my first post so bear with me.
Thanks,
Chad
Old Feb 11, 2007 | 01:13 AM
trackguy1211's Avatar
trackguy1211
Default RE: My '01 1500 engine light is on!! need help!
My '01 has the same problem. I havent checked the code yet, but when my truck is at idle it doesnt run very smooth. A few weeks ago it would die when I put it into gear after first starting it, unless I gave it a little gas to get the rpm's up. But lately it's running fine, but the check engine light is still on.
Old May 22, 2007 | 03:20 PM
82lowe36id's Avatar
82lowe36id
pull the plug wire off on #6 cylinder while running. Any change in the way it idles? If yes, then it is most likely fuel related. If no, than start checking things in the ignition system......wires.....plugs.......rotor.....cap... ..
