Racing Talk Talk about any racing here, whether it be street/strip, NASCAR, F1 etc.
Why Titan, Why ?
Old Sep 8, 2005 | 08:17 PM
  #51
HemiMan4451's Avatar
HemiMan4451
Default RE: Why Titan, Why ?
anyways titans have the 4 valves a cylinder thing. but like they said, try taking a ram rc 4x2
Old Oct 29, 2005 | 03:26 PM
  #52
sysengr1's Avatar
sysengr1
you gotta love MOPARTODD. The best comeback for Nissan Titan owners I've ever seen....
Old Dec 3, 2005 | 08:51 AM
  #53
Possum1's Avatar
Possum1
quote
Doesn't handle as good? Sorry but your info is flawed, even though its a truck, it handles better than all of them. Who cares how it handles. It will out last your dodge, it will pull more than your dodge, haul more than your dodge if you want to get down too it. Oh and next time race someone who know how to drive a Titan. VDC kicked in cuts out alot of power from the Titan. Prevents wheel-spin.
do u want to put ur money where u mouth is i have a 1978 3/4 ton club cab long bed dodge( there is ur out last see where yours will be in 28 years) and a 2001 3500 dodge quad cab take ure pick our run out tow out last o i failed to mention the 78 is a 440 truck i love to see svt truck running around hahaha and i pull gooseneck trailers with both that would brake your trucks rear suspenchin just to hook to
Old Dec 7, 2005 | 02:02 PM
  #54
King Calibra's Avatar
King Calibra
ORIGINAL: 71RoadRunner
From what I have read and seen you have done nothing to prove any of your claims and only given the ammo to prove you wrong, such as the handling and ride issue. The only reason the Titan won in acceleration is becaust the Ram is full time 4 wheel drive where the Titan has the best of both worlds since it's switchable between 2WD and 4WD. With this setup it has the best of both, it will engage 4WD on launch and disengage it afterwards applying full power to just 2 giving it more power to the ground. The only way to test them fairly would be to have the Titan against a 2WD Hemi Ram, although the Titan will still retain the launch advantage since the 4WD will engage, but it could be evened up by running the Ram with slicks. Although from what I have seen, a Hemi Ram 1500 with a SWB will beat the Titan time and time again. I suggest that you provide proof of what you keep trying to claim, that is a fair comparison and not an off balanced one like you've already posted, or go elsewhere because talk is cheap.
Owned! [sm=chairshot.gif]
Old Dec 7, 2005 | 05:25 PM
  #55
highrevr/tflea's Avatar
highrevr/tflea
wheres his dyno-proving his claims of his 500 whp stang??? In Alaska?? Do they even have dynos there?
