Racing Talk Talk about any racing here, whether it be street/strip, NASCAR, F1 etc.
my neon vs. 330Ci --- no joke.
Old Aug 18, 2004 | 02:37 AM
  #21
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: my neon vs. 330Ci --- no joke.
im running a 340, +.030, low compression...i run 87 octane to race...
727 tranny, 3000 stall, 4:10 gears...26x11.5x15 hoosier QTs.
Old Aug 18, 2004 | 02:56 AM
  #22
moparmanjames's Avatar
moparmanjames
Nice, I just picked up a 340 for my Demon and I can't wait to drop it in. Those engines are getting hard to find out here.
Old Aug 18, 2004 | 06:23 AM
  #23
71RoadRunner's Avatar
71RoadRunner
There are no worries about a 440 Roadrunner with 3.23 gears keeping up with an M5 on the top end, it will chew it up and sh*t it out. My Roadrunner which also has 3.23 gear easily could peg it's 150 MPH speedo and that was with a stock '73 400 high performance engine in it at the time. Due to it's nose being higher and air getting under it and shaking the hell out of it, I backed out of it with plenty of pedal left at 145 MPH. I would love to see how nice and easily it would run up and beyond that now since the nose is leveled and it has the mildly built 440 in it.[sm=smiley4.gif][sm=smiley2.gif][sm=icon_sneaky.gif][sm=hia.gif]
Old Aug 18, 2004 | 11:24 AM
  #24
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i am a believer in mopar supremacy...but i just dont see a 3 speed auto BB car built to drag race giving any real challenge on a long run...just based on the premise that the M5 is built for a road like the autobahn,..im not saying the RR couldnt keep up..id just have to see it to believe it...
*not flaming*
Old Aug 18, 2004 | 11:32 AM
  #25
moparmanjames
Thanks 71RR, I was going to mention that but I thought I'd let it go.
I imagine if I wanted to go roadracing and added an aero package and put the 4 speed back
in it would probably hit 165 before the windows popped out of it.
If I reinforced the windows and went with a 2.76 gear, I'm guessing 185 or so.
What did they run back in 1970 in Nascar? I know they were Hemis in 1969, I cant remember if they were in '70 also. I know in '71 they were running 440's and finished 1,2,3, and 4 in the southern 500 with 426 wedges, but that was with the more aerodynamic body style.
Old Aug 18, 2004 | 11:37 AM
  #26
moparmanjames
Badstrat, are you talking in the twisties or just flat out top end on the highway?
I know it would lose in the curves.
Old Aug 18, 2004 | 11:42 AM
  #27
moparmanjames
Badstrat, by the way a new M5 has about 505hp but only 383ftlb of TQ. It's all top end.
A mild 440 (such as mine) will easily make over 500ftlb of torque.
That's what will get you top end, the ability to push your brick through the air at that RPM.
Old Aug 18, 2004 | 12:35 PM
  #28
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
im not flaming, by any means. but id have to think the top speed of a new M5 is higher than a 3 speed BB..just a thought...those are great numbers though...do you know a stock 1/4 time for the M5?
Old Aug 19, 2004 | 05:44 AM
  #29
71RoadRunner
There are 2 M5's, one has a V10 and it's 507 HP and the other has a V8 with 396 HP, which are you refering to? Either way they have a 155 MPH top speed and 4.8-4.9 sec. 0-60 MPH. I have found absolutely no 1/4 mile data on the M5's at all. They do weigh over 2 tons as well.
As far as high speed running goes, it's all a matter of horsepower, torque, weight, gearing and aerodynamics. The B-body cars can get up into the 165-175 MPH range with a decently built 440, automatic and 3.23 or 2.74 gears. To get above this speed would require either alot of aero work or alot more power. I know that mine will reach into that range on the top end. Any engine will need to be built for sustained high RPM's to keep running at those speeds for a good amount of time, such as an oil cooler and a trans cooler. My Roadrunner will beat the **** out of an M5 in every acceleration test made, but it will not out handle one and it probably would not hold up very long at top speed. So if your talking about the usual freeway romp, then the M5 is toast, but if you talking for around 50 miles I wouldn't even try it, legal or not.
Nothing I've read of yours about this has even hinted at flaming, don't worry.[sm=itsok.gif][sm=innoc.gif]
Old Aug 19, 2004 | 11:24 AM
  #30
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
well..i just wanted to make sure..."Some people" here...tend to always take to the hostile side...
