Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Dana 44 front ?Studs?
Old Aug 15, 2007 | 04:12 AM
killerdodge1980's Avatar
killerdodge1980
Default Dana 44 front ?Studs?
i noticed that on the passenger side of my 1980 power wagon's front Dana 44 axle it has 2 studs instead of a u bolt to bolt the leaf springs to the axle. i am wanting to put an add a leaf lift on my truck but i will need to get longer studs and i was wondering where and if i can get these studs but a couple inches longer.
Old Aug 16, 2007 | 04:20 PM
stormer426's Avatar
stormer426
Default RE: Dana 44 front ?Studs?
A good hardware store or industrial supply bolt kinda place or, you can not bottom the stud in the housing to get some extra threads, questionable practice there! 9/16-12 x 9/16-18 x desired length, double ended stud or maybe a length sized bolt, I never tried using a bolt though.
