ramcharger will not start on incline?
I've heard of the problem, but never had it. Depending on if its carbed or not, try checking the floats, see if they are sticking, or maybe the fuel is not getting in there, does it just turn over or does it want to start, what sounds does it meke. Think about these questions and how a hill can effect your fuell system, I hope this helps.
it's fuel injected, and that's what i was told about it when i bought her. I personally haven't had any problems yet, but I'll keep those in mind if I do. Atleast I can tell the lady she isn't crazy. she told me she had her own personality... I actually believe that. I was told she left it at the dealership overnight, for an "oil change" and that's when it started happening to her... once again thanks for the tips on this...
If it does it when you getlowon fuel, pull the tank and have look. The tank might have been banged on the bottom and bent/broke thepump assy,or maybe knocked the baffle loose.Correct me if I'm wrong, I think these use the coiled tubing type pump assy. My F.I. came off a pick up. Never seen a Ramcharger set up. My old '86 4X4 had this problem after I installed the factory '88 F.I. with an external pump. The tube was bent up about 5' off the bottom. Hung a weighted hose on mine to make sure it stays submerged no matter the angle of the truck. Sounds likeyours issucking air instead of fuel.Be worth a look.
ORIGINAL: rampar410
hey chump could it be a short or a lose wire ?? my coil wire did this to me.. like to have never found it.. quinn
If I knew this problem was able to be reproduced anytime parked on an incline, I would try a shot of starting fluid first to see if it fires up for a few seconds and then go from there.
