1983 D50 Diesel
RE: 1983 D50 Diesel
I'm not sure what the stock gear ratio on them mitsu trucks are. However 35's according to statistics call for 4.56 gears. I found that 4.10 gears actually run better on the truck because you can actually drive it on trips down the e-way without it screaming like a raped pig. As I'm sure you know the bigger the number...the shorter the gearing....short=torque...tall=speed. So you have to figure out what you're gonna use the truck for. If you want it for a driver....any where from 3.73 to 4.10.....a puller...4.10 for sure...or a torque monster for the rocks or trails...4.56 on up.
