Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
NO FUEL TO TBI!!!!! 89 Ramcharger
Old Feb 25, 2008 | 02:32 PM
89chargerguy's Avatar
89chargerguy
Default NO FUEL TO TBI!!!!! 89 Ramcharger
Well i got an 89 Ramcharger, 360, holley 2B TBI, 727 and i runs great until just recently when i went to start it and it cranks fine ad it has spark, but no fuel is getting into the throttle body.And this past weekend i changed the fuel filter. I am stumped and ive read some stuff about a fuel pump relay, and an ASD, and i would be so thankful if someone could please help me get my only vehicle running again.
[IMG]local://upfiles/84720/0627AA94A28F4BC2824E88F309350210.jpg[/IMG]
Old Feb 25, 2008 | 08:57 PM
moparborn's Avatar
moparborn
Default RE: NO FUEL TO TBI!!!!! 89 Ramcharger
When you first turn the key on you should hear the pump run,if not check the fuse,check to see if the relay is clicking,if yes to both,check for power to the pump,if yes=pump
Old Feb 27, 2008 | 07:20 AM
89chargerguy
well i changed the fuel pump and left the lines off to start and see if fuel came out and nothing, reconnected the lines and went back to it a day later. Had the girlfriend sit in it and start it while i bang on the bottom of the tank and it started, but it will sputter out and keeps doing this. Dont wanna have to drop the tank but think im gonna have to, leaning towards fuel pump replacement.
Old Feb 27, 2008 | 09:57 PM
livinginh's Avatar
livinginh
Thats odd for it to go out with out any warning, This is going to sound like a dumb question, but you didnt get the filter on backwards did you? It almost sounds like the sock at the end of the pump/sending unit is blocked up, when you bang on the tank your knocking the stuff off the end of it.
Old Feb 29, 2008 | 02:37 AM
Chump's Avatar
Chump
First thing...do you hear the pump run for 2 to 3 seconds when you turn the key to "on"...not "start". Yes or no?
It's possible that you have a bad pickup assembly in the distributor. This sends pulses to the computer, if the computer does not see the pulses it will shut down the ASD relay and powerto partsof the fuel and ignition system.
Did you pull error codes off the computer?
First pull the negative battery cable off for about 5 minutes and re-connect. Try to start truck and then check codes as follows...
Displaying & Reading Trouble Codes
Accessing Codes
With Check Engine Lamp
To start the function, cycle ignition switch ON-OFF-ON-OFF-ON within 5 seconds and any stored fault code will appear. Check engine lamp will display the code by flashing on and off. There is a short pause between flashes and a longer pause between digits. All codes displayed are 2 digit numbers with a 4 second pause between codes. The lamp will flash until all codes are displayed then 55 (end test) will appear.
Old Mar 3, 2008 | 12:52 PM
89chargerguy
Well i dropped the tank and changed the fuel filter and did all the fun work, it was the problem and now it works, thanks for all the help and advice. Now I have a new problem, and the fuel guage wont work, stupid me. So im not gonna take the tank out again, instead i think im gonna cut a hole in the floor and pull the sending unit straight out, which is what i should have had done in the first place and was just wondering if anybody out there has every done such a thing for this kinda job??????????????????????????
Old Mar 5, 2008 | 10:10 PM
livinginh's Avatar
livinginh
Yep been there done that. 35 gallon tank full of fuel was not going to try and drop it. Just remember, most of the tanks are plastic, so be carefull how deep you cut, and watch for the cross supports when you cut. Also, remember the sending unit is farther back then you think,,,lol. Best is after you cut, go to a junk yard and cut the floor section out of a old Dodge truck bed, and trim it just a hair bigger then the hole you cut, rust proof it, seal it and screw it over the hole, so from now on it will be easy to get to your sending unit.
Old Mar 6, 2008 | 11:50 PM
trx450's Avatar
trx450
Old Mar 8, 2008 | 11:50 PM
rampar410's Avatar
rampar410
i dont think i would do that again ..there is a brase across there over the pump. and it is hard to cut and i cut into one of my connections at the fuel pump and they are hard to find.my 02 quinn oh yes the floor is ribed and the piece u cut out is now to small to cover it,,,
