Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Fuel Leak
Old Apr 7, 2008 | 07:34 PM
moparjonzo's Avatar
moparjonzo
Default Fuel Leak
I believe it's coming from the tank, but i'm not sure how the tank is mounted. is it bolted, or clipped?
90 with 318, tow package, RWD(only)
thanks in advance
Old Apr 11, 2008 | 01:37 PM
BIG HOOK's Avatar
BIG HOOK
Default RE: Fuel Leak
It's supported by 2 metal straps, hooked on the front end with j-bolts attaching the straps in the rear. The tank is probably not a metal tank, I believe it would be a heavy duty plastic tank, not likely to leak unless it was punctured or something. More likely your leak is coming from a fuel line.
Old Jun 4, 2008 | 11:02 AM
moparjonzo's Avatar
moparjonzo
I traced all the fuel lines, and found it was thethe Evap. Canister.
thanks for the advise though
