Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
360 Tune-up
Old May 2, 2008 | 07:53 PM
otterby's Avatar
otterby
Default 360 Tune-up
I've got a '73 Power Wagon 3/4 with a 360 that I can't seem to get to run right. Below 1500 rpm is not so rough but when you push on the throttle it acts like its flooding out and even backfires occassionally, it's really bad when the engines not hot. Above 1500 rpm it runs like a dream.I'm not good with carbs so thats probably where the problemis (its a Holly 2 BBL). I've timed the engine and replaced all the basics. Any advise on where to start?
Old May 3, 2008 | 12:14 PM
mackster's Avatar
mackster
Default RE: 360 Tune-up
Sounds like A excellarator pump problem - clogged, ball not seating, wrong excellarator pump cam.
I have had the same problemn a 4-Barrel, wrong cam on pump.
Old May 3, 2008 | 09:48 PM
lugnuts's Avatar
lugnuts
Make sure the vac advance is workin' and hooked to the correct port also. No vac. till you open the throttle.
Old Jul 12, 2008 | 08:04 AM
Bushmaster150's Avatar
Bushmaster150
Also sounds like a loose timing chain. Check your timing, and see if it changes drastically above 1500 rpm, or if it seems to bounce around. My father in law had the exact same symptoms on his 360 PW. Chain was loose, and actually rubbing the timing cover.
