Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
probs with carb upgrade
Old Jul 12, 2008 | 09:58 PM
goddad's Avatar
goddad
Default probs with carb upgrade
I have a 1987 Dodge Ramcharger, I have been working on for a while now and I am so close to getting it back on the road but I've run into a problem.....
My Ramcharger is 318 Auto trans I put an Edelbrock performance Cam, Lifters, Intake, and 600cfm carb (electric choke). I had to purchase a 1" spacer plate so that the new carb would clear the EGR Valve. Now the problem I have is that the kick-down bracket when mounted doesn't fully engage and also looks as if it could bind the throttle cable. Also I can not reconnect the cruise because it does bind up the entire works. I installed the additional Throttle Lever Adapter. Just looking for some advice and or possible products that could help fix this.
All help is appreciated, Thanks
