Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Old 08-05-2015, 12:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
Play in steering on 83 Ramcharger
Old 05-12-2009, 11:22 AM
looney's Avatar
looney
looney is offline
just ask @ the dodge dealer for a steering shaft coupler rebuild kit. they all can order them. took my shop a day to get it.
Old 05-16-2009, 02:00 PM
RamCharger85's Avatar
RamCharger85
RamCharger85 is offline
Default play in sterring
I had such loose play in my sterring it was like steering a sailboat. found out it was the steering coupler. had it replaced and it's perfect now. trouble is finding parts for an 85 RC is getting tougher.
Old 06-07-2009, 01:01 PM
scaggs68's Avatar
scaggs68
scaggs68 is offline
I had the same issue, only thing is that the coupler was bad as well. I found a good one in a junk yard off of a 3/4 ton truck. My kit was about $16 when I got it from dodge. I still had a little play after the rebuild, I think I will add a steering stabalizer next. If that don't work, I have another gear-box.
Old 04-28-2014, 01:48 PM
dinwiddie69's Avatar
dinwiddie69
dinwiddie69 is offline
Default 83 ramcharger
on my 83 ramcharger it was steering box was loose i put some lock tight on bolts now its fine get some one to move wheel back and forth while you look at box and other components which evers moves is your prob
Old 04-28-2014, 08:31 PM
RDuck's Avatar
RDuck
RDuck is offline
Borgeson in my 79. Fixs all that ails you.
My bell joint fell apart on the hey at 70mph. $1 pick a part part later it was fixed. Then bought a Borgeson and never looked back
Old 10-22-2014, 08:54 AM
fifayou's Avatar
fifayou
fifayou is offline
It's perfect now.
______
fifa 15 coins
Old 11-14-2014, 02:20 AM
ryan0714's Avatar
ryan0714
ryan0714 is offline
i finally got tired of the play in my 93' ramcharger and it was coming from the coupler. instead of buying the borg, i went to the junkyard, and found 2 steering shafts off off 90s jeeps, they had the u-joint couplers from the factory. bought the 2 of them, chopped the ends off that i needed, only one end of the shaft is the correct size for the box. then i chopped the ends off the original ramcharger shaft, and took the rag joint and all that off. weled the new u-joint ends onto the ramcharger shaft. then u must grind down the indexing spline inside the couplers cuz its to big, but once u get it shaved down then you just tap the new shaft on and tighten it down with the bolts that go through the couplers. paid a total of 15 dollars i think, been good ever since.
Old 01-02-2015, 01:56 PM
The War Wagon's Avatar
The War Wagon
The War Wagon is offline
Thumbs up
Originally Posted by ducktail
Borgensen or something like that amnfacturs and sells a replacement steering shaft that will take a lot of play out. Replaces that joint.
You WON'T regret it! Pics of mine.
I went with the Borgeson steering shaft on mine as well.
Old 01-23-2015, 04:02 AM
Rattle's Avatar
Rattle
Rattle is offline
I have no idea of weather it's an easy fix...but I do know that the alignment will affect how it moves on the road.
Old 03-07-2015, 11:54 AM
Rammajama's Avatar
Rammajama
Rammajama is offline
Its a 83...good change steering gear box is worn. If you want it done right. Change the whole assy. Rag joint, steering shaft (Borgeson all the way) and new steering gear box. (I went with Red Head)
It was a PITA but now my 91 RC steers and drives down the road like a brand new truck. WELL worth it in the end. Good luck!
Quick Reply: Play in steering on 83 Ramcharger
