Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
1986 Ramcharger, wont start
Old Jul 25, 2008 | 07:46 PM
Mplover's Avatar
Mplover
Default 1986 Ramcharger, wont start
I have a 1986 ramcharger that wont start, when i turn the key i get a click sound, and it thats about it. I got the battery tested, cleaned all the terminals and checked all the wires for loose connections and i couldnt fine anything wrong, i think it might be the started but i would like to get a second opinion of what it might be, thanks
Old Jul 26, 2008 | 02:19 AM
goddad's Avatar
goddad
Default RE: 1986 Ramcharger, wont start
you might want to check your timing and/or ignition system
Old Jul 30, 2008 | 01:59 AM
jacobbruning's Avatar
jacobbruning
you might try bridging the gap[running a jumper wire]at the electrical connections at the starter selenoid on the starter. if this causes the motor to turn over then it's propably your starter relay. you might try turning over the engine manually to make sure the motor is not locked up also.[back yard mechanic]
