Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
lifted 88 rc needs help
Old Aug 27, 2008 | 01:29 PM
88rhyno's Avatar
88rhyno
Junior Member
Default lifted 88 rc needs help
i wanna take my 4inch lifted rc and redo it so that it can handle pretty much any offroading that i throw at it but i need suggestions about axles lockers gears and motor and trans im new to the offroading thing and im just tired of breakin it all the time any help would be appreciated
Old Aug 29, 2008 | 10:48 PM
BigBad84RC's Avatar
BigBad84RC
New Member
If you're careful the stock axles should hold up fairly well, but if you break em' you can either put money into them with stronger components, or upgrade to 1 ton axles. As far as lockers go, you want a selectable locker in the front, but an automatic locker like a Detroit locker will work fine in the rear, or if you don't drive on the street that often you can get away with a spool, or a Lincoln locker(welded differential) in the rear. Stock motor and trans will work fine, but if you don't have the right gear ratio it will seem underpowered. Hope this helps.
