Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
85 dodge ram charger
Old Jul 16, 2009 | 08:52 PM
nrhramman's Avatar
nrhramman
Unhappy 85 dodge ram charger
i can not start the engine with the key i have to jump the wires from the starter why is it like that
Old Jul 20, 2009 | 02:21 PM
dipsherry's Avatar
dipsherry
the ignition switch could be brokein or else a wire broke goin from the ignition to the starter
Old Jul 20, 2009 | 03:42 PM
nrhramman's Avatar
nrhramman
it clicks but dont turn the starter over
Old Jul 21, 2009 | 02:09 PM
dipsherry's Avatar
dipsherry
well i would start by looking at all the wires comming from the started check to make sure they are tight and your ground is clean also check to see if any wire is broke
Old Jul 21, 2009 | 02:10 PM
dipsherry's Avatar
dipsherry
if that is not it then i would say that the solenoid on your starter is bad
Old Jul 21, 2009 | 05:52 PM
nrhramman's Avatar
nrhramman
the guy that replaced my engine also said something about a clip for my transmission cuase my dial aint going to drive or any other one can that be the problem
Old Jul 22, 2009 | 12:06 PM
dipsherry's Avatar
dipsherry
i would seriouley doubt if that would affect it in any way.does your truck go into gear at all or is just your indicator does not show what gear it is in
Old Jul 22, 2009 | 12:30 PM
nrhramman's Avatar
nrhramman
just my indicator dont move
Old Jul 22, 2009 | 07:55 PM
nrhramman's Avatar
nrhramman
found out it was the netural safety switch after i replaced the starter and ing switch lol
Old Jul 22, 2009 | 11:12 PM
dipsherry's Avatar
dipsherry
yeah that sucks when u have to do that...as far as the inicator it is just a lil line behind your dash if you wanna fix it take the gauge cover off and you will see where it should connect my rc had that problem
