1986 ramcharger engine questions
hi iv got an 86 with a 318-727 trans my question is its been sitting for about 4 years what can i do to get the engine running that wont hurt anything im kinda flying blind here.
first, pull the plugs and see if it turns over freely, and wouldnt hurt to put a little oil in the spark plug holes, a tune up--plugs, wires, cap, rotor, all oil and filter change, probably have to pull the carb and clean it, new fuel lines would be good, and if you have bad fuel in the tank, well start pulling your hair out now, there are ways to clean it, but i have never had very good luck with it, the best option is to find a clean tank and replace it, if the fuel just smells bad and is all still liquid you will be ok with a drain and flush, but if it has varnished or has other contamination, it really sucks, good luck
DT75, thanks for the tips! I have an '85 Ramcharger, same 318 motor and trans - also been sitting several years. I know I need a new radiator and suspect a bad fuel pump.
Have been meaning to get her running again, but the lousy gas mileage kept it back burnered.
