Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
91 Ramcharger won't charge
Old Sep 20, 2011 | 10:30 PM
Beast91's Avatar
Beast91
Default 91 Ramcharger won't charge
Hey everyone,
New to the forum, but I have a 91 Ramcharger. I love this truck. It is not charging the battery. I have replaced the battery and the alternator. It is registering on the tester at the local parts store as not charging, but the alternator is good. I am thinking short somewhere, but can not find anything although I barely know where to look outside of the obvious. I just got back from Afghanistan this week and while I was gone my buddy was driving the truck. The issues started while he was driving it, so I don't know if anything tell-tell happened before the issue started. Any help or experience with this problem is helpful.
Old Sep 21, 2011 | 11:31 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
The voltage regulator I believe is build into the PCM. But try looking for one on the bulkhead/firewall.
Old Sep 27, 2011 | 08:05 AM
71dodge's Avatar
71dodge
if there is a voltage regulator on the fire wall its directly behind the air cleaner. i may be wrong but i think after 90 the were built in?
Old Sep 27, 2011 | 09:00 PM
Beast91's Avatar
Beast91
I am pretty sure it is the voltage regulator. I just got back in town, but left it sitting for the week just to see if anything was draining the battery while the ignition was off. The battery stayed charged, so I ruled out a short somewhere like that. I will be under the hood this weekend and the voltage regulator is where I am starting.
Old Oct 3, 2011 | 06:49 PM
Beast91's Avatar
Beast91
Got it! I was planning on changing the voltage regulator, but it was working fine. I found a loose bolt near where the wiring was grounded. I tightened it and everything started charging.
