Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
1975 W300 Throttle linkage.
Old Apr 13, 2014 | 07:57 PM
Rogue427's Avatar
Rogue427
Default 1975 W300 Throttle linkage.
I have a 1975 W300 that I got in parts. No engine. I picked up a 318 for it.
I got in running but the throttle cabel looks to long for the bracket, unless you clamp on the plastic part of the cable. This is a 4sp truck. We had a 1976 W350 fire truck with a stick and that cable looks shorter then mine. The guy at the parts store says my cable runs to the front. He usually is good with his info. I have the one that bolts to the back and spring return bracked to the front, just cable length seems wrong. Anybody have pictures of a 74 with 4sp. Thanks
Old Apr 14, 2014 | 07:03 AM
RDuck's Avatar
RDuck
Get a new cable or modify your bracket.
Old Apr 14, 2014 | 09:25 AM
Rogue427's Avatar
Rogue427
Thanks
Old Apr 15, 2014 | 10:47 AM
Daves69's Avatar
Daves69
Can you post a picture? Hard to visualize something that has or may have been modified over the years.
A lot of folks are going with the Lokar throttle cable rather than using the old stuck stuff.
http://www.bing.com/images/search?q=...=0-24&sp=-1&sk=
Old Apr 15, 2014 | 04:36 PM
Rogue427's Avatar
Rogue427
Thanks Dave.
I think I will order 1. I looked at them on ebay, just a little more then I wanted to sped. But don't want the throttle sticking so I will blow the dust off of the credit card.
My 1975 W300 was a old Air Force truck then a Town truck from Montana.
4x4 4sp. PTO winch, 318 with 5:89 gears. I have only a little $$$ in it. Truck was only $500 witn no engine.
I did put a new oil pump and timming chain in it, just wishing I would have put the 340 cam in it.
