Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
1992 Ramcharger turn ignition check engine turns on fires, no light no start
Old Oct 11, 2019 | 03:06 PM
92RamYazzie's Avatar
92RamYazzie
Arrow 1992 Ramcharger turn ignition check engine turns on fires, no light no start
I replaced fuel pump. There was a short found after pump replaced. Truck started, ran. It stalled cuz short in wiring rats are through. Found repaired. Pump ok. Now, I turn key no check engine light no start. Sometimes it comes on fires right up and runs great. Is it switch, I get no spark when no check engine light does not turn on. I'm lost, when it starts it runs Beautiful
Old Oct 12, 2019 | 08:12 AM
Moparite's Avatar
Moparite
Sounds like the ignition switch, The pcm is not getting power from the switch that's why the light is not coming on.
