Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Ram charger at a standstill
Old Sep 18, 2020 | 10:59 AM
Rigar1994's Avatar
Rigar1994
Originally Posted by Moparite
Throttle body injection doesn't have a crank sensor, It does have a pick up coil but all that is for is running the ignition. You may want to take off the air cleaner and shine a light down the throttle body(while it's running). Look to see if both injectors are spraying. Also how is the idle motor? When they start to have issues they cant keep up with the motor running(not adjusting fast enough). Keep your foot on the gas a bit above idle and see what happens.
hmm, word. Imma have to find a diagram of the entire ignition system and just track it piece by piece, maybe I’m missing something somewhere. I’ll see about checking the fuel pressure and such too
