Ramcharger Lift
Has anyone lifted a 2wd ramcharger? the rear is easy but the front is being problematic. My ramcharger is toooo clean to get a 4x4 and swapping for a 4x4 i think will be too costly. Any suggestions please? Thanks all!
No one makes dropped or raised spindles for any of the 70-80's trucks or vans. The one item I saw that would raise the Ramcharger speciffically and or the pickup models is a spacer that fits in the spring pocket on the bottom a arm This spacer only lifts at most two inches. The other alternative would be a Bell Straight "Gasser" axle used on 55 Chevys, but here again it will 'cost' probably more than you want, or be about as much effort as putting a 4x4 axle under it form a donor unit. Monroe used to ? make shocks with external springs that would probablt give a couple inches lift. We're sort of out of luck with Mopars in that respect, and boy, someone could make a boatload of $$$ with dropped or raised spindles for Mopars. I believe the Durango has applications...But, it's only here-say. Another thing I remember seeing was the use of Chev springs, I believe they were Impala springs, but again, for lowering only I think.
The article about the Chev springs was on '*********' forum.
