Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
360ci with 318 heads
Old Aug 23, 2006 | 02:27 AM
ram1985's Avatar
ram1985
Default 360ci with 318 heads
i was offered a 360 ci short block for 25 bucks at school and i was wondering if the heads and intake from my 318 would bolt up to the block. to make an easy 360ci long block... anyone with answer please help
Old Aug 23, 2006 | 03:55 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: 360ci with 318 heads
They will bolt up and work, but they will raise the compression of the engine.
Old Oct 9, 2006 | 08:16 PM
f0x672's Avatar
f0x672
if they dont destroy your piston rings... your A.OK... have fun with that
Old Oct 10, 2006 | 07:47 PM
Junior5290's Avatar
Junior5290
It will bump up compression and would work. My friend had an 85 ram with that combo and 36 swampers, that ram had power and sounded pretty cool with dual flow masters.
Old Oct 15, 2006 | 03:20 AM
JarheadX's Avatar
JarheadX
lemme kno how that goes
Old Oct 15, 2006 | 01:32 PM
HemiLonestar's Avatar
HemiLonestar
If its the old style heads, not only will it raise your compression but the ports and valves are much smaller than a 340/360 cyl head and won't deliver enough airflow. If they're Magnum heads then it won't matter.
