Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Rod link to cable
Old Sep 26, 2006 | 01:52 AM
Hawkstr's Avatar
Hawkstr
Default Rod link to cable
Looking for some help/advice
I have done my searches and there are no write ups or DIY's on this.
Wanting to convert my 3 part kickdown linkage rods to cable (like on the newer Dakota, Rams, RC) might do the shifter at the same time due to some of the brackets needed also hold the shifter at the trany over the linkage with swivel bracket with plastic bushings and rubber plugs.
working on:
Make Dodge
Model W2 - W200
Body Style 4 - Conventional Cab with Sweptline box; Hi Line Wagon
Gross Vehicle Weight B - 6,001 lbs to 10,000 lbs
Engine F - LA 360 V8 2V
Year 1974
Plant S - Warren Truck #1
Wheelbase 131,149
Rating 3/4 Ton
Sequence Number 089646
Build Number 89646
360 LA 2bbl
727 Torqueflite auto
Divorce setup
NP205 T-Case
Dana 44 front PT
Dana 60 Rear
