Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
84 Ramcharger Spark Problem
Old Sep 28, 2006 | 11:18 PM
Ymmit's Avatar
Ymmit
Default 84 Ramcharger Spark Problem
[size=2]I have a 1984 dodge ramcharger that loses spark. When I start the engine it will stay running while in the start position on the ignition switch. When I let the ignition switch back to the run position it shuts off. If I run a jumper wire from the battery to the positive side of the coil it will stay running all day long. Any help on a cure would be greatly appreciated.
Tim
[/size]
Old Nov 2, 2006 | 01:05 AM
rampar410's Avatar
rampar410
Default RE: 84 Ramcharger Spark Problem
tim there are several things to look at 1st is the relay in the driver side.. i cant remem ber whatis called 2nd there is a switch on the stearing col. it moves down when u turn the key to start try thoes 2 first qp
Old Nov 8, 2006 | 08:04 PM
mills's Avatar
mills
I don't know what all you've done, but in addition to checking those two relays you should start at the ignition coil and work your way towards the spark plugs and check everything.
I just replaced the ignition coil on my 86 Ramcharger because for some reason, the coil's post wasn't correct and the cable that connects from the coil to the distributor was not making a good connection. I replaced it with an Accel SuperStock coil, which had the right kind of post, and the truck has run great since.
Old Apr 27, 2007 | 12:06 PM
IGadget's Avatar
IGadget
HAh, I know this one well... If you havent already fixed it it is the Ballast Resistor. Drivers side firewall two wires on one connector and a single on the other.
Old May 5, 2007 | 07:25 PM
Chump's Avatar
Chump
Ballast resistor.
Old May 30, 2007 | 06:10 PM
dnfd737's Avatar
dnfd737
I had this problem with my old ramcharger turned out to be a "pick up plate"(atleast thats what I remember the guy calling it)in the distributer
