Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
84 Ramcharger
Old Jan 14, 2007 | 04:45 PM
lefka1's Avatar
lefka1
Default 84 Ramcharger
Replaced battery with Autozone 1000amp ca. Then alternator quit, replaced alt & checked output with voltmeter across batt. terminals ,reading was too high at 15.3 volts. It should be between 13.5 to 14.5 volts . Changed regulator {external}three times ,no change. Basically everything is new in the charging circuit.Can anyone help?
Old Jan 20, 2007 | 09:38 PM
darrell8937's Avatar
darrell8937
Default RE: 84 Ramcharger
ivolt over max, I probaly would not worry to much. There is only one thing that would cause over voltage, the regulator,
Old Jan 22, 2007 | 12:58 AM
lefka1's Avatar
lefka1
Thanks for the advice.
