5.9L, 5.2L, 3.9L, and 4.7L Custom Ram Air - DIY
Old Jul 16, 2009 | 09:36 AM
Dans01Durango's Avatar
Dans01Durango
Hmmm... It seems I can move the TCM lower towards the original air intake or right on top of the wheel well. A couple of sheet metal screws to hold it in place... I'm gonna have to look into that. Will do a full write up when I can and when the weather permits. Here in NYC we're looking at thunderstorms until Sunday... Damn...
Old Jul 16, 2009 | 09:41 AM
Dans01Durango
I see your point Fac, but won't that be the same thing as having the original air intake? What the two gurus (hydra and Indy) are trying to teach me and others is how to get a homebrew ram air install to work on our Ds. You have it simple cause you don't have the TCM in the way like 4.7Ls do. Which I have and that's why I'm being yelled at and prodded to figure out for myself...LOL... JK guys!
Old Jul 16, 2009 | 10:35 AM
IndyDurango's Avatar
IndyDurango
I was concerned over water in both my piped setup (similar to how you guys are doing it) and when I moved over the the functional Ram Air hood. Never has been an issue over the years. I believe it is overrated as a concern.
When driving in the rain/water/etc... ever concerned over the gapping holes between the fender wells that enter into the motor area? That area is 100X larger than any directional pipe we are working on here in the future.
IndyDurango
Old Jul 16, 2009 | 09:06 PM
Dans01Durango
Okay you all know my dismal first attempt at making a homebrew CAI:
https://dodgeforum.com/forum/1st-gen...console-2.html
Here is my second attempt I hope I redeemed myself hydra and Indy.
First I disconnected the TCM wireloom using the bolt to loosen the connection.
Okay, here's the TCM's bolts: It has three one right at the top middle of the TCM bracket and two on the bottom of the bracket.
I had to bend the tab that was protruding out of the bracket cause it was getting in the way of the frame. I also bolted the bracket into the frame using one of the existing bolt holes.
Then I zip-tied the top bracket hole because it didn't line up with the fender wall. Then I tightened the bolt to make the connection.
I then reconnected the tubing and widened the opening throughout the length. Notice how much better the tubing looks?
Another view of the reroute. I like the way the TCM is out of the way freeing up more space for more airflow!!!
The homebrew scoop for the ram air.
Before it was a scoop. I cut off the narrow end just enough to screw the tubing in to make a secure connection and I cut off the lip at the opening of the funnel.
The view after I zip-tied the scoop to an a/c line.
The view through the grill.
I think the relocation of the TCM will not affect the cooling properties of the fins cause it has been relocated right in front of the original air intake so it will get airflow no matter what. Okay, this long entry has come to an end. Now for the feedback be they good or bad. All is welcome.
Old Jul 17, 2009 | 10:03 AM
jumpwake's Avatar
jumpwake
Nice work, could you tell a difference from your prior setup? I think I may try moving the PCM as well. I have one question though...I ordered a 6x9 K&N, but I haven't seen any pics on how people are attaching them inside the airbox. Do I need to buy an adapter of some sort?
Old Jul 17, 2009 | 11:24 AM
Mean Green's Avatar
Mean Green
It just drops in. That setup looks pretty good Dan. Definitely make sure the TCM gets enough airflow to it take the D for a spin and check the temp of it when you get where you're going. I' don't think it will be an issue but just verify.
Old Jul 17, 2009 | 11:28 AM
Dans01Durango
Thanks jump. I'll know the diff when I take my family to a friend's house upstate this saturday. You mean the TCM, right? The PCM is located near the driver's side firewall(?). Do you have a 4.7L as well? The k&n filter replaces our standard filter like Mean said.
Old Jul 17, 2009 | 11:31 AM
Dans01Durango
I kinda had a feeling the TCM heats up due to the fins...LOL... I got lucky the old intake hole was right there to give it some airflow. I'll definitely check that out when I get to my friend's house.
Old Jul 17, 2009 | 03:24 PM
hydrashocker's Avatar
hydrashocker
Looks good Dan!
This is what I'm going to use as a funnel. It's a simple black plastic pipe flashing for the roof and it has a rubber seal. Looking at moving the temp sensor first though.
http://www.lowes.com/lowes/lkn?actio...B34&lpage=none
Old Jul 17, 2009 | 11:27 PM
Dans01Durango
Pipe flashing!!! D'oh!!! Why didn't I think of that??? I was just at home depot too!!! Maybe you don't have to move the temp sensor... Why not cut a piece off the collar that would be touching the sensor? Or don't cut it cause the sensor is usually behind a rubber shield originally, right? I assume you're gonna mount the "scoop" long side down to catch more cold air?
