Timing question
Old Feb 24, 2017 | 11:04 AM
fishermanof93's Avatar
fishermanof93
Default Timing question
ok all so i have read a pretty healthy amount about it being good to retard the stock cam 4 degrees. my question is when you do this do you adjust your ignition timing any? that is all
Old Feb 24, 2017 | 11:39 AM
What year, what engine?
Old Feb 24, 2017 | 11:51 AM
fishermanof93
1988 carburated 318
Old Feb 24, 2017 | 05:13 PM
moparborn's Avatar
moparborn
You will loose bottom end performance retarding your cam.
Old Mar 2, 2017 | 11:11 AM
fishermanof93
thanks for the info i went back together as it was when i took everything apart. it was running good and for whatever reason the distributor has started failing now which is awesome. it has a loose wire connection somewhere. now the question is to try and fix it or upgrade to something like this
Amazon Amazon
Old Mar 2, 2017 | 06:23 PM
Moparite's Avatar
Moparite
That's no upgrade this is...
The pick up in your distributor may be going bad that's no need for a new distributor.
Old Mar 3, 2017 | 08:18 AM
fishermanof93
jigle the wires in distributor and works again for a while would it just be the pick up??
Old Mar 3, 2017 | 09:07 AM
fishermanof93
why wouldn't HEI be an upgrade. everything i see = stronger spark/ better. but i don'r know please feel free to educate me
Old Mar 4, 2017 | 07:57 AM
Moparite's Avatar
Moparite
The hei is just a replacement, Less wires no ballast etc. If you get the msd6a you will notice a difference. At least i did when i replaced the stock ignition(also used with a accel super coil). You still need the stock distributor and pick up then just wire up the msd box. It supplies (6) sparks every time if fires, Hence the name 6A. But you need to check things out before throwing parts at it. Replace the pick up and see if that solves your issue.
Old Mar 8, 2017 | 12:14 PM
fishermanof93
ok so I think i got it running right again i think it was very late last night when i found the bad ground. i rewired the distributor. it is far from stock but i have no idea what it is and don't know if i can add the 6a to it. but like i said got good fire now so we will wait and see. changed coil to MSD's coil which does make more power supposedly on its own so we will see how this set up works. thanks for the help.
