2000 dodge durango owners manual pdf
ON the back side of the T-case, there will be a round tag with the identification info for your transfer case. Need to know which one it is. There were a couple different options...... (NV231, 242, etc.)
)Steve
According to the shifter, your Durango is kinda/sorta all wheel drive. The "4wd" selection is for normal driving, and all four wheels get power, with differentiation in the t-case between front and rear drivelines. (for turning corners and such on high traction surfaces.) 4hi lock is "real" four wheel drive, for use ONLY in low traction conditions. (deep snow, mud, or off-roading.) 4 Lo lock is low range 4 wheel drive. (no differentiation in t-case, front and rear are locked together.) For use in truly knarly terrain, or, to pull your boat up that REALLY steep ramp.
Thanks again for the help.
I would stay out of 4 lock, unless the roads were completely covered in snow. The 4wd selection should prove perfectly well for most any on-road driving conditions, unless, of course, you get stuck.... the Hi lock.
As an update, I got the linkage sorted out
thanks for all the help. Oh, and before I forget, the rubber bushing for the linkage can be obtained at O'Riley's Auto parts for about $10...as compared to the stealership where one was $19...If I can find the part number from O'Riley's I will post it...it was simply hanging on the blister pack isle with all the generic parts.
Thanks again for the help...one step closer to getting Red on the road again!
thanks for all the help. Oh, and before I forget, the rubber bushing for the linkage can be obtained at O'Riley's Auto parts for about $10...as compared to the stealership where one was $19...If I can find the part number from O'Riley's I will post it...it was simply hanging on the blister pack isle with all the generic parts. Thanks again for the help...one step closer to getting Red on the road again!
Does anyone have a copy of the Owner's Manual (glove box type) that they can scan or share the transfer case section with me? Trying to figure out the shift pattern on the new to us 2000 Durango...when we picked it up, it was missing the linkage between the shift lever and the t-case...when I was looking at the pattern on the selector sticker it appeared not to have a 2wd/Awd position and IF I read it correctly, 4lo was all the way forward...
Thanks in advance
Steve
Thanks in advance
Steve
