Add A Leaf Center Pin
2001 Ram 1500 4x4. Already have about 3" on front via lift coils and spacer. Want to add a leaf to give it a little rake as soon as it isnt Cambodia hot in SW Miss. I have the leaf but no replacement center pin. It appears to me that the center pin in the rear leafs now will not be long enough to reuse and I did not get a new one with the kit (or have lost it since i purchased the kit???).
What size and type bolt could I use instead or do you guys think the center pin in the leafs will be long enough?
Thank y'all in advance!!
I would get one from a lift company. Or summit. Something that should work properly, not just a random bolt.
The pin on my AAL install was the worst part of the complete 3" kit. Took til lunch to install the complete front end, and the rest of the day to do two AAL in the back. It sucked. Grinding, cutting, pounding. Next time, I'll just spring for new leaf pack.
