Transfer case motor
Old 09-22-2017, 10:04 PM
tsfoster4's Avatar
tsfoster4
tsfoster4 is offline
Default Transfer case motor
If the transfer case motor was bad would it just cause the lights on the switch to be dimmed and barley visible. I have already tried to replace the switch and replaced the tccm which I pick up from a local junk yard.
Old 09-23-2017, 09:52 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
It could be the mode sensor on the transfer case. It tells the TCCM what position the transfer case is in.
It gets power, 5v, from the TCCM.
The system can be scanned for codes? Might be easier than swapping out parts.
Old 09-23-2017, 11:13 AM
tsfoster4's Avatar
tsfoster4
Where exactly is thats sensor at?
Old 09-23-2017, 01:33 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Here you go.
File Type: jpg
Old 09-23-2017, 01:36 PM
tsfoster4's Avatar
tsfoster4
Here you go.
Ok thank you is there a way to test it with a. Multimeter to tell if it is bad?
Old 09-23-2017, 03:05 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Not sure.
The schematic shows it as a 4 pole switch - BUT with a 5 volt supply that's not part of the switch.
File Type: pdf
