Dodge ram 1500 4.7
Dodge ram 1500 4.7
I had pull heads and redid the valve at machine shop. Pt all new gaskets,water pump, oil pump, radiator, thermostat, spark plugs, and coils. Starting the truck in morning or when its been off for a bit, white smoke smell like oil comes out of the exhaust. Its aggregating after so much money spend pls help
I had put an injector number 7 because it had giving me a 7 misfire when i got it back from the shop, but yhe injector i replaced was a little bit wider at the mouth on top, but the auto part got the injector it called for in the system. But it sure looked bigger opening on top. I was wondering if that would make a difference.
