Transmission Pan
Old 01-21-2018, 11:24 AM
byronpen's Avatar
byronpen
byronpen is offline
Default Transmission Pan
I have a 2009 Dakota. I cant find a transmission pan that will hold extra fluid is there one out there.
Dont want to put a extra transmission cooler in.
Old 01-21-2018, 07:02 PM
FaceDeAce's Avatar
FaceDeAce
FaceDeAce is offline
The 4wd pan is a bit deeper and holds more than the 2wd. Same bolt pattern. Different pan filter is needed for the deeper pan. Other than that, definitely add a transmission cooler up front to support your towing plans. The cooler really is not hard to do and is not expensive either, $100. It will save your transmission.
Quick Reply: Transmission Pan
