Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Upgrade transmission?
Old 06-19-2018, 05:45 AM
multi-tine's Avatar
multi-tine
multi-tine is offline
Default Upgrade transmission?
i have a stock 6 speed trans on my 2006 5.9l. I just added a H&S Mini Maxx programmer and I am sorta scared to put it on performance bc the trans wasn’t built for that kind of power. I don’t know much about transmissions. What do y’all recomend I should jump up to while keeping it a manual. And how soon should I look into getting it
Old 06-19-2018, 09:04 AM
Wow. I don't think the NV5600 will even handle the torque the stock motor puts out...... Interesting. No clue what you would have to go to for an upgrade.
Old 06-26-2018, 09:16 AM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
Im thinking he should have the G56 since it’s an ‘06. Either way the stock clutch will slip before he even gets close to hurting his trans. OP, is reverse to the right and up or to the left and down?
Old 06-26-2018, 10:10 AM
ZEN357's Avatar
ZEN357
ZEN357 is offline
Here's what you want..... http://www.rpmtransmissions.com/page67.html
If you can afford it go for Stage 7
Old 06-26-2018, 11:18 AM
Nate_rs's Avatar
Nate_rs
Nate_rs is offline
I think OP needs to tell us what he’s going to be doing with the truck before he drops $6k on a transmission. Both the NV5600 and the G56 can hold considerable power in stock form. They can definitely hold up against a tuner
Quick Reply: Upgrade transmission?
