3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Truck has blue smoke from exhaust, runs ruff, idles with slight misfire, poor acceleration, oil leaking from EGR valve. Starts up with no problem.
Truck is a 2004 Ram Laramie 1500 5.7 hemi,
Compression test might help , as well as change spark plugs an wires and coil packs , pcv valve needs replaced as well as egr valve or at least gasket , If its been awhile since a good tuneup these things would help maybe even clean throttle body ,,scan for any codes even stored codes if no engine light
