Thump in floorboard
Old 04-25-2024, 05:12 PM
KameronG11's Avatar
KameronG11
KameronG11 is offline
Default Thump in floorboard
I've got a 97 dodge ram 1500 4x4 and I rebuild the front end a couple months ago and replaced all the shocks. It rides alot better but its not the smoothest ride when driving on rough roads. Here recently everytime I hit a pothole or something I can feel and hear a clunk in the floorboard. Any idea what that could be?
Old 04-25-2024, 08:04 PM
HeyYou is online now
Received 3,197 Likes on 2,949 Posts
Control arm bushings?
Did you torque the shock bolts to spec? As I recall, they get some stupid high torque value, 110 ft/lbs or so.
Old 04-26-2024, 05:55 AM
Moparite's Avatar
Moparite
Moparite is offline
Was the track bar replaced?
Old 04-26-2024, 07:53 AM
KameronG11's Avatar
KameronG11
I didn't torque the shock bolts to 110, I just used a impact to tighten them up and yes I did replace the track bar maybe it needs some grease?
Old 04-26-2024, 10:15 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Lightbulb
Yes, the new track bar requires greasing after installation with a grease gun. It also needs its bolts torqued to specs or bumps and rattles may occur. Double check the torque spec on the shock bolts, too. That could also cause similar bumps and rattles, if not torqued properly.
Quick Reply: Thump in floorboard
