[5th Gen : 08+]: Pacifica injectors in Caravan
Can I use a 2017 Pacifica injectors in my 2017 Caravan?
I had a code P0205, which is the number 5 cylinder circuit open and took it back to the dealer. Dealer tells me that its the number 2 injector that's bad. Ok, well they replaced the #2 injector, ran fine for 1 day and now I'm getting code P219A , which I read can be from not using a Mopar injector and using a cheaper one .
Pacifica injectors are $70-100 per injector cheaper. So id like to replace them all with OEM and see if that fixes the code, as I didn't have a code before this.
